radiator replacement
VolvoTurbo850
- Year and Model: 1994 850 (T5)
not as high as you think. IT will go down and you can move it under the engine itself. If you prefer you could use ramps and that should do.
The Fleet
2001 V70 (NA) 2.5
1999 C70 Conv. Turbo 2.3 HPT
1998 S70 Turbo (T5) SE
1994 850 Turbo (T5)
1980 Corvette (Corvolvo)
Previous Possessions: (4) 240's, (1) 740, (9) 850's, (5) 70 Series
Projects on the go: NONE... Yet!
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
I have these, and they gave me just enough room to get it out.
http://www.northerntool.com/shop/tools/ ... _200205524
I don't know if the 6 5/8" is how far they get it up off the ground? They're not terribly tall, but give you enough room to get under there and work.
'98 S70 T5
2016 Chevy Cruze Premier
VolvoVieve
- Year and Model: 2000 C70
Im replacing my 2000 C70 radiator- do you have an easy tutorial i can check my haynes against?
thanks
Vieve
thanks
Vieve
jblackburn
This is a basic guide that I used to show you all the screws and everything you need to remove to get it out of there:
http://volvospeed.com/volvo_repairs_how ... ement.html
'98 S70 T5
VolvoTurbo850
Note the C70 has one extra reinforcement V bar on the engine cage/frame which you have to remove to get the radiator out.
The Fleet
2001 V70 (NA) 2.5
1994 850 Turbo (T5)
MatDesign84
- Year and Model: 1997,855 T5
+1 on oil changing ramps.
Currently: 1997, 855 T5 | 1998 Subaru Legacy GT 2.5
Previous: 1997, 850 GLT | 1993, 850 GLT | 1988, BMW 325i, 1990 Volvo 240 DL
"That's good to know though in case they let loose again, but I swear if they do, I'll punch something." -jblackburn
- 3642 Views
Last post by t3yf5g
- 7191 Views
Last post by jalwlb
- 238 Views
Last post by volvolugnut
- 1182 Views
Last post by neworleans
- 1901 Views
Last post by dosbricks
