Hi, I'm looking to change the FRONT rotors on my 2000 V70, can anyone give me any tips before I get started? Any special tools I will need? Anyone have any links to step by step pictures?
Any help would be greatly appreciated.
2000 Volvo V70 Rotor Replacement
remove pins, remove pads, remove calipers(15mm) and hang them up by wire. take out 10mm pin, knock rotor off
I like volvo rotors because they come with new mount bolts and painted center part. rebuild caliper seals if you want to(cheap and fun to do).
99 V70XC 158K
95 850glt 188K
95 850glt 188K
SimLyons
- Year and Model: 2001 V70 T5
When you reassemble the front brakes be sure to use the correct torque "steps" on the wheels and use the "star" pattern to apply the torque. Not doing this is the leading cause of warped rotors.
Sim
confused_al
- Year and Model: 1996 TLA wagon
96 850 Platinum Wagon
98 MB ML320
06 V70
95 850 GLT(RIP)
98 MB ML320
06 V70
95 850 GLT(RIP)
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
Have a small sledgehammer at the ready. One of mine took near 10 minutes of beating the heck out of the thing as hard as I could to knock it off.
'98 S70 T5
2016 Chevy Cruze Premier
vjaneczko
- Year and Model: 2006 S60R
- Been thanked: 7 times
In that write-up, he uses a pair of pliers to compress the piston back into the caliper - DO NOT DO THAT! There's a good chance you'll push at an angle and scar the metal or screw-up the gasket. Instead, head to AutoZone (or your local favorite) and spend 9 bucks on a brake spreader. It really should be called a piston compressor, but whatever . . .
I'd also get a bottle of brake grease and lube up everything - forget that little packet the comes with some pads. First, it makes sure squeaks are kept to a minimum. Second, it smells great - what, am I the only one that thinks that?
Since you're down there, take a look at your ABS pickup sensors and give 'em a good scrub-down to keep 'em clean.
1997 855 GLT - R.I.P.
2006 S60R - For ME!
2006 S60R - For ME!
- instarx
- Year and Model: XC70 T6 2011
- Has thanked: 1 time
Well, don't pry directly on the piston. If you put the old worn-out pad in front of it and pry on that it is fine to use pliers IMHO. But the spreader does make it easier.vjaneczko wrote:In that write-up, he uses a pair of pliers to compress the piston back into the caliper - DO NOT DO THAT! There's a good chance you'll push at an angle and scar the metal or screw-up the gasket. Instead, head to AutoZone (or your local favorite) and spend 9 bucks on a brake spreader. It really should be called a piston compressor, but whatever . . .
2011 XC70 T6 - current
2017 Alfa Romeo Giulia Q2 - Totaled in 2022. Not my fault.
2011 XC60 - sold
2000 V70XC - given to a friend, wish I still had it.
2011 XC60 - sold
jblackburn
I pushed my floor jack and caliper up against the control arm and pushed [the piston] back in against it using the jack.
'98 S70 T5
- 32 Replies
- 6677 Views
Last post by MrAl
- 1957 Views
Last post by MadeInJapan
- 3175 Views
Last post by styoung94
- 1761 Views
- 1900 Views
Last post by mecheng
