Speaker Problems in a 91 240
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
KeithDell
Year and Model: 240 1991
Post by KeithDell »
Thanks, in advance, for the support.
I own a 1991 240, and I'm having trouble with the speakers, and I'm not certain the cause. I have no sound coming from the rear speakers and only the faintest sounds coming from the front. Based on reading the other postings on this topic (specifically: https://www.matthewsvolvosite.com/forums ... =2&t=23121), it seems as though I have an amplifier problem. Of course, my larger problem is that I don't where to proceed from here.
Any chance you can outline how I might verify if my problem is with the amplifier or speakers and then what my next steps should be?
phils94850
Year and Model: 2009 s60 turbo
Post by phils94850 »
Keith, welcome to MVS !
I guess I need to know what all are you doing ? Are you just replacing the speakers ? Did you just all the sudden lose sound ? What kind of headunit do you have in the car and any aftermarket hooked up such as amps ?
1996 Platinum Edition
KeithDell
Post by KeithDell »
Hi, Phils,
Thanks for the welcome and the quick reply. Simply stated, my goal is to restore sound to the vehicle. Right not I'm trying to determine the reason that I lost sound (breakdown of speakers themselves or another cause).
I'm working with all original equipment, including the factory-issued headunit. I don't think there's been any aftermarket hook ups, but I'm not certain.
I bought the car used about 4.5 years ago, and I don't remember there being any sound from the rear speakers. Over time I lost almost 100 percent sound in the front driver speaker, and recently I lost most of the sound from the front passenger speaker. It seems as though I can fade sound from left to right using the volume dial (though I was under the impression that the 240 volume fade was front/rear, not left/right).
Thanks, again, for your help--that's the Hoosier hospitality I know and love (called Indiana home for most of my childhood...and still every Christmas).
phils94850
Another hooooosier :) it sounds to me like your headunit is slowly going out on you. Id replace it first and go from there.
KeithDell
Post by KeithDell »
Well, that sounds as if it'd be an easier fix than an amp issue. I'll give it a shot and let you know what comes of it. Thanks, again, for the support.
