Help Everyone,
I just did an oil change because I noticed that my oil looks like a cup of coffee, creamy brown (see the pic)
Is it that I have a leak somewhere or a busted gasket or something else?
Up to 2 weeks ago it was normal looking. The car has never overheated at all.
I replaced the radiator 2 months ago because I I had a yellow cream in my radiator overflow
I had thought it was a leak in the radiator causing it. At that time the oil was clear but
the radiator fluid had the creamy stuff in it.
I still have the yellow cream but in lesser amounts.
Somebody please give me ideas how to proceed.
Thanks in advance.
JJR
creamy looking oil?
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Thanks for the pic. I have heard of the chocolate milk but have never seen it till now. From all I have heard you likely have a bad head gasket or something along those lines. Is the car smoking from the tail pipe?
fazool
- Year and Model: S60, 2007
- Been thanked: 7 times
What you see is an emulsification of water and oil. Essentially, coolant (water and antifreeze) are getting into your oil.
As stated, the most likely culprit is a bad head gasket. because of the suction and pressure on every piston stroke is sucks water into the cylinder which runs down the cylinder gets into the oil.
To be blunt, yours looks rather extreme.
2007 S60 2.5T AWD (Daily Driver)
2001 S60 2.4T (Daughter's Car)
2003 S80 2.9 (Son's Car)
1995 850 2.4 (Daughter's Car - sold off)
2005 S40 2.4i (Bought new - since sold)
1986 740GLE 2.3(First Volvo - sold off)
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
Time for a compression and/or leakdown test.
'98 S70 T5
2016 Chevy Cruze Premier
boosted5cyl
- Year and Model: '98 V70 T5, '99 S80
Looks nasty. Does the 850GLT have an oil\coolant heat exchanger? I would look there first.
'04 XC90 2.5T AWD (Angus) 134K.
'99 S80 T6 (Medusa) 214k. On borrowed time LOL
'98 V70 T5 (Vivienne). RIP @ 228K. Spun rod bearings.
jblackburn
A '97 has it built into the radiators like our 98's do.I replaced the radiator 2 months ago because I I had a yellow cream in my radiator overflow
'98 S70 T5
boosted5cyl
Ruh Roh. Well, I'll clutch at straws then for the OP....jblackburn wrote: '97 has it built into the radiators like our 98's do.
-When the rad/oil exchanger was swapped, moisture already existed in the oil but there was no apparent emulsification when checked.
-Dud replacement rad/oil cooler.
- 2023 Views
Last post by oragex
- 772 Views
Last post by dorvin
- 862 Views
- 709 Views
Last post by volvolugnut
- 2127 Views
Last post by fitz548
