intake gasket need replaced
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
diveshark09
Year and Model: 2006 S60 2.5T
Post by diveshark09 »
How do you replace the intake gasket :x And what should I replace while im at it thanks
Choguy03
Year and Model: S40, 2000
Post by Choguy03 »
I'm guessing you are talking about the intake manifold gasket? Why are you replacing it? Either way, I would replace the PCV while you have it out. We can give more guidance once we know the year and model.
Sent from my BlackBerry 9810 using Tapatalk
diveshark09
Thanks for the reply I need to set up my profile.With that said i have a 2006 S60 2.5t 79k and I started the car and it acted like is was going to stall message came up check engine came up triangle ! came on and it was not as smooth running as before.So took it in and they said it needed a intake manafold gasket ,ports plugged ,oil box,and a couple of other things that go with the problem.I did not get the codes.Thanks for any help or opinions.
hanzbe420
Year and Model: 2006 s60 2.5T
Post by hanzbe420 »
sounds like you need to order a pcv kit and do everything. cause the kit includes the gasket the oil box the hoses and all the rest of the parts.
confused_al
Year and Model: 1996 TLA wagon
Post by confused_al »
diveshark09 wrote:... it acted like is was going to stall message came up check engine came up triangle ! came on and it was not as smooth running as before.So took it in and they said it needed a intake manafold gasket ,ports plugged ,oil box,and a couple of other things that go with the problem.
Your problem could be very well started from a broken top hose of oil trap box, which then resulted the whole breathing circuit clogged up.
https://www.matthewsvolvosite.com/forums ... =9&t=44137
Note: That plastic hose only used from 2006-2008, Volvo uses older version (all rubber) after that.
96 850 Platinum Wagon
98 MB ML320
06 V70
95 850 GLT(RIP)
