Here are the codes that I have on the car currently. I guess my question would be: Is there something on the car that is causing all of these errors, and / or could they all be fixed by replacing a fuse?
ABS: No fault found.
AUM-41FF: Amplifier, sub - antenna Signal Missing; DTC (What does that mean?) is found not active.
CCM-003: Fan motor passenger compartment temperature sensor Faulty signal; DTC is found not active.
CEM-1A5D: Communication with the ETM control module Signal missing; DTC is found not active.
CEM-6A03: Door locked left rear signal too low. DTC is found not active.
DDM-0022: Power window hall sensor 1or 2 faulty signal. DTC is found not active.
DDM-003F: Control, door mirror signal too high; DTC is found not active.
DIM: No Fault Found
ECM-1100: Outside Temperature sensor - signal too low; DTC is found active.
ECM-2910: Front heated oxygen sensor (HO2S), bank 2 heating - signal missing; DTC is found active.
ECM-2A0A: Rear heated oxygen sensor (HO2S), bank 1-Signal missing;DTC is found not active.
ECM-2A2A: Rear heated oxygen sensor (HO2S), bank 1, heating - signal missing. DTC is found active.
ECM-430D: Leak diagnostic, minor leak- DTC is found not active.
ECM-5000: A/C pressure sensor - signal missing; DTC is found not active.
ECM-91A7: Throttle position (TP) - faulty control; DTC is found not active.
ECM-91F0: Throttle position (TP) - faulty current; DTC is found not active.
ETM: No Fault Found (I think this is a bit odd, so I think the car maybe confused on this one. LOL)
PDM: No Fault Found
PSM: No Fault Found
REM: No Fault Found
SRS: No Fault Found
SWM: No Fault Found
TCM: No Fault Found
UEM-0004: Siren Communication Fault; DTC is found not active.
Any help with this would be great. Even if it was put into lamen's terms for me. It seems pretty easy to understand, but if I had a little bit more info on these it would help a great deal!
Thanks in advance!
