1983 240DL Fuel and Spark but won't stay cranked
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
98T5
Year and Model: V70T5,98' / 940,93'
Post by 98T5 »
I've gone thru this car and checked all the common "no start" issues and:
1. New in-tank fuel pump installed (old one died)
2. Fuel pump relays work(2 of them)
3. Replaced ALL fuses in kick panel with correct amp fuses
4. Fuel Pressure Regulator (FPR) is working (no gas smell, wetness or leakage from diaphragm side of FPR)
5. Fuel rail is getting fuel (Which tells me the pump/relays both work fine)
6. Old IAC appeared dead(not humming but should have faint "humming" sound) tried one from the junkyard, same result, no "Humm"
7. Spark to the Coil (but could the coil itself be bad? how to tell?)
8. Spark to the plug wires
9. Brand new battery
10. Starter lights up and engages perfectly everytime
11. Ignition switch turns over fine (but could it still be bad?)
The symptom is simple, the car will turn over for about 2 whole seconds, then dies. MY DIY hunch is the IAC is the culprit (#6 above) but Any advice you guys can offer is much appreciated. 8) ..
Car has been sitting the last 3 weeks because of this issue. sux :cry: :cry: :(
98’ S70 T5 Turbo Manual - Midnight
01' S60 T5 Turbo- Brandy
98' V70 T5 Turbo - Swifty
93’ 244 n/a - Mr.Chill
91' 940 SE Turbo - Mojo SOLD
83' 242 DL - Bluto SOLD
93' 940 Wagon - Django - SOLD
:mrgreen: 8) :mrgreen:
98T5
Post by 98T5 »
26 views and nobody has a clue? :?: :cry: sux
