Stabilizer Link
WinterDriver
- Year and Model: 2004 XC90 T6 AWD
Does anyone have a guide or diagram to replacing the stabilizer link on an '04 XC90 T6? Thanks for the help!
Tonyx
- Year and Model: 2001 XC70
- Has thanked: 3 times
- Been thanked: 8 times
I've done both fronts and back links. What specifically did you want to know?
If you don't have impact wrench, I don't recommend you diy. The ball ends are bugger to take off due to corrosion and it will free spin due to the ball joint(now worn).
I recall needing the following:
Air impact wrench
Narrow jaw vice grip
Metric sockets
Fronts you'll need to take wheels off, rears can be done with both wheels just off of ground. Besure to briefly tighten the ball joint nuts first to break the corrosion before loosening. It's short burst on an impact wrench to tighten then reverse direction and full trigger to loosen.
Air impact wrench
Metric sockets
2003 XC70 230K and counting..,
tatonka12345
- Year and Model: XC90 2008; S60 2002
I was able to change the front links on my 02 s60 without an impact wrench, although having one would have made my life a little bit easier. I had to use a wire brush, PB Blaster, and vise grips instead. There's another thread here that was helpful also
https://www.matthewsvolvosite.com/forums ... 11&t=43971
- 2300 Views
Last post by oragex
- 15 Replies
- 5468 Views
Last post by Keithnysm
- 1272 Views
Last post by jimmy57
- 47 Replies
- 7826 Views
Last post by jantt
- 10191 Views
Last post by SuperHerman
