p0016 code after replacing timing belt
vcso_wrench
- Year and Model: 2003 v70 2.4t
Just changed the timing belt on my, 2003 volvo v70 2.4 turbo i-5. The code came on after 30 minutes of running the engine. Replaced the idlers and tensioner and the water pump. I think the problem started when trying to remove the crank pulley. I didnot know that the dampner would come off so easily i used a puller to get the crank pulley off. I then got the pulley off and used a large socket and then tapped the pulley back against the block. I still had thetiming belt on at the time. The new belt went on with no problem. This is got to be the easiest belts to do. Just dont know where to start, to try to fix this problem. This is my 1st volvo. I love this car. I work on so many different types of vehicles. Never had a problem like this after doing a timing belt. If anyone has any ideas. I really could use the help w/ our 1st child on the way in a 10 days. I dont like having the check engine light on. Thanks, vcso_wrench
JRL
- Year and Model: Several
- Been thanked: 16 times
You probably knocked the timing off a tooth, now you need to find someone who knows how to re time it CORRECTLY
vcso_wrench
so could be just a matter that i got the vvt cam gear off a little bit. Do you know where i can get a good manuual for this car. Mitchell online doesnt have good images of the timing marks for this engine. I think that the exhaust cam has the variable cam movement to it. Thanks vcso wrench
jenkinskg
- Year and Model: 04 c70 hpt 98 s70 xc
- Has thanked: 1 time
replaced s60 2004 belt was off by one tooth, got code
marked belt, moved over 1 tooth, all good many months and miles later, no big deal
2004 c70 2.3HPT, s60 2.5T
jenkinskg
did the one tooth thing myself on 04 s60, no big deal
Got a sproket locking tool , did my 04 c70 much easier.
FYI did both cars never removed crank pulley, only removed plastic cover, 2 10mm bolts, 1.5 hrs easiest timing belt ever
Tonyx
- Year and Model: 2001 XC70
- Has thanked: 3 times
- Been thanked: 8 times
jenkinskg,
Did you rotate crank to position, past it 1/4 turn CW, then turned it back CCW to alignment with the notches on the belt cover? Just curious if this is necessary to bring VVT in line during the belt change.
2003 XC70 230K and counting..,
jenkinskg
Changed a few timings belts so far, no crank pulley remove needed, can do it under 2 hrs
Using cam lock tools makes it twice as easy because nothing can move.
2 10mm bolts under crank get removed, that is all that is needed
jenkinskg
Found vvt hub on a v70 guy is selling parts from. All codes gone. Just ordered motor mount. Did a bad thing, test drive with top mount removed
- 1768 Views
Last post by marcels
- 25 Replies
- 12198 Views
Last post by jmartin919
- 14164 Views
Last post by steveatlast13
- 6219 Views
Last post by Mike Langlois
- 1866 Views
Last post by Tundra12
