At Auto Zone I jacked into the OBD ii located in the seat console of my V70T5, it gave me a no codes reading then a PASS reading, would this then indictae that the ABS MODULE does not need re soldred by VICTOR, if so could it be my wheel sensors, or is there another OBD PORT.
JIM
OBDii & ABS and TRAC LIGHTS
Only dealers and indy shops with VADIS or high end scanners can access the ABS codes.
Autozone scanners can only read the ECU codes, if you don't have any ECU codes then the scanner believes everything is OK.
What is the problem with your ABS?
Have you visited my website?
Here's information I have on this subject.
Vitor's ABS website
Vitor's ABS website
01 S60 2.4T, 99 S80 T6, 98 V70, 96 850 GLT, 03 Mini Cooper S, 92 Chevy Suburban
- 2103 Views
Last post by lcc014
- 693 Views
Last post by rspi
- 26 Replies
- 7166 Views
Last post by Roger_850T
- 1793 Views
Last post by CDoore54
- 12 Replies
- 2493 Views
Last post by zeke1256
