I have a few questions and I hope you can help me: I have a 2001 S80. Could you please tell me what...and more specifically where is the "position bulb"? And what does it mean that I have a "bulb failure"?
Also, just recently I went on vacation and when I came back, on two seperate occasions, all of my speakers shut off except for the front center one. Later after driving for about 30 minutes they came back and then shut off again and then came back on. They have been fine for about a month now but I'm afraid of that happening again. Could you help me understand what might be going on with that?
THANKS!!
Sarah
Position Bulb failure
Volvo Oil Sump O-Ring Replacement
I had a similar problem when I first got my S80, it turned out that there are two light bulbs on each of the back red light (The ones that are on while your drive), if one of these bulbs is not on, burns or does not make good contact you will still have the other light on the same side where it burned and the message will appear. I fixed this and never have had a problem again.
Check that out and see if this fixes your problem
Regards,
Regards,
- 4911 Views
Last post by Oly850
- 4879 Views
Last post by adrian22
- 4146 Views
Last post by silentcircuit
- 2640 Views
Last post by firstv70volvo
- 24720 Views
Last post by JNavas
