2001 S40...what tranny fluid
I hear so many opinions. I have a 2001 S40 with 100+K miles on it. I want to 'drain and fill'. What fluid do I use? It is an automatic, NOT manual.
- MoVolvos
- Has thanked: 312 times
- Been thanked: 524 times
AlanS wrote:I hear so many opinions. I have a 2001 S40 with 100+K miles on it. I want to 'drain and fill'. What fluid do I use? It is an automatic, NOT manual.
2 0 0 1 VOLVO S40 & V 40 - ATF Dexron III and Mercon - Very Generic
http://new.volvocars.com/ownersdocs/200 ... v40_09.htm
The 714 20W is all I use unless I am out or just need a quart or two... Attachment was provided by my Local Swepco Rep.
http://www.pelicanparts.com/catalog/sho ... o_pg10.htm
SO...you like the Swepco product for a direct replacement for the original Volvo tranny fluid? Which weight...10 or20w?BKM98 S70 T5 wrote:AlanS wrote:I hear so many opinions. I have a 2001 S40 with 100+K miles on it. I want to 'drain and fill'. What fluid do I use? It is an automatic, NOT manual.
Is it compatable with what is in the box now? Since it is a 'drain and fill', I will be mixing the products until a few fills.
- MoVolvos
I've used Swepco for over a dozen years now both the 714 20W and 306 15W-40 motor oil. Unless the winters are extreme then the 5W-30.
http://www.pelicanparts.com/catalog/sho ... detail.htm
Good info about oils including Swepco
http://www.lnengineering.com/oil.html
Independent uses Swepco. It is where I am picking up my ones and twos as it is sold by the case through my Local Rep.
http://www.yelp.com/biz/independent-vol ... lnut-creek
It is compatible but being most people are afraid to do a DIY Flush I recommend you do a drain and fill and let it run a couple hundred miles and then a Flush for peace of mind.
S40 Transmission Fluid Change?
https://www.matthewsvolvosite.com/forums ... sion+flush
Transmission fluid color
https://www.matthewsvolvosite.com/forums ... =1&t=47877
jimmy57
- Been thanked: 320 times
Your 2001 uses JWS3309/Volvo 1161540/Toyota T-IV since it is the AW55-50 5 speed transmission. Look in the owner's guide and it will show you the correct fluid.
2000 was the last year for the 4 speed unit that uses Dexron/Mercon fluid in the S40/V40 models.
- 2227 Views
Last post by shiloh51933
- 13 Replies
- 3712 Views
Last post by mrscullini
