Repair Door Hinge Stop, 850
byeboy
Year and Model: 850R, 1997
Post by byeboy »
The door hinge stop wears out, allowing the door to 'flop' open, without those little 'bump-sops' in between, and also to just swing shut, with nothing keeping it open, I ordered a new hinge stop ("Door Check") from FCP Groton ($35.00, free ship) after living with a worn out one for over a year.
Original Driver's Door Hinge Check far side (178,000 miles), and the new one:
You get to it by removing the inner door panel...not at all difficult. First you (carefully) pry the upper panel insert off. Its made from thin particle board stuff, and will snap like a saltine cracker,so 'nudge it off the three plastic buttons holding it in place: If you break it, I suspect some glue (I like Goop) or tw0 sided tape will make an invisible repair when you re-assemble everything.
There are two Torx screws under there to remove
Then there are five or six T-25 Torx along the bottom edge of the door to remove...then this "hidden/sneaky" bolt that is the lower right speaker bolt holding the panel on:
After these are out, the black flat handle that you pull to open the door is simply mounted with a pressure foot spring, so just pull it up and off....then the panel will wiggle up, then off the door.
That red plug in the upper right is where that long speaker bolt went!
At this point, having done it once, it would take me only five minutes to get here, just to give you an example of time needed.
The Check is behind this little access door (Thank you Volvo!). It just pops of, and the hinge check unbolts from the "outside", with two 10 mm nuts and a T 30 Torx.
When unbolted the check is rotated 90 degrees 1/4 turn (swing bottom towards door skin) then wiggled out.
I attached a Zip Tie to the floppy T30 part to help me guide it back through the hole.
It will not go through the hole in the correct position, It must be rotated 90 degrees to fit...You'll have to discover this for yourself.
Put some white Lithium grease on the contact surfaces,remember to put the rubber boot back on (I put mine on backwards, I think...but it still seems to work.
Retrace your steps and you are finished!
Sure is nice to have that all fixed..I suspect the dealer would have charged about $350.00 to do this...
januwan
Year and Model: 97 850 NA 209 K
Has thanked: 7 times
Been thanked: 3 times
Post by januwan »
I just finished this job and would recommend to remove all speaker screws and disconect the speaker before taking panel off. It will install easier and you will not have to twist and flex panel during installation.
januwan
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 112 times
Post by E Showell »
It is best to attend to this repair at the first signs of a failed door check. Failure to do so may result in cracking of the actual sheetmetal of the door or door pillar. Both are weak spots. If you get a break in either place, the only viable repairs involve welding and are thus significantly more complex than simply replacing a failed door check.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
camjohns
Year and Model: N/A 850 97, 850R 96
Has thanked: 6 times
Post by camjohns »
Is there a difference between the parts for the passenger and driver side? looking on fcp groton, was unable to find a specific driver side part. Thoughts?
Ben850
Been thanked: 7 times
Post by Ben850 »
The part you referred to as the original is also an aftermarket piece. It is the same as the replacement piece, so it has been changed at least once already.
The OEM original piece is heavier, and uses bolts to hold it to the door. It is also usually painted with the car.
Not a big deal, but the origial pieces are nicer, and smoother operating.
Also, regarding the above post, Both sides are the same, just flipped upside down. I noticed the aftermarket part designates a right and left, but OEM only differs front and rear.
1996 850 Turbo Wagon White.
1994 850 N/A Wagon Black.
1997 850 Sedan Black.
1996 850R Wagon White.
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 20 times
Post by jblackburn »
'98 S70 T5
2016 Chevy Cruze Premier
Ben850
Post by Ben850 »
It is too late for me to add this photo to my other post, but I found this original piece on ebay for $13.
Bolts instead of studs.
door check.jpg (8.39 KiB) Viewed 3812 times
Incidentally, I found a salvage piece after buying a replacement from FCP. I installed the salvaged piece and still have the new part as a spare.
