About 5-10 minutes into my drive to lunch, the car starts taking off really slow from red lights, like it's in 'limp mode.' I checked and the 'winter mode' button hadn't been pushed. I drive it extra easy, but it threw 'transmission system service required' message. A few minutes later, it gives me a brake failure message, ABS and Brake light indicators turn on, and most of the instrument cluster stops working. Interestingly, the water temp, speedo, tach, and trip odometer stop working, while the rest of the gauges/displays function properly.
Here's what it looked like (the engine is running and I'm doing 20-30 mph at this point):
At this point, I'm close to my destination so I park and eat. I figure the car can rest, and I can fuel for whatever I have in store for me. An hour and a half later, I start the car and see that the gauges are back, but it's now thrown an 'engine system service required' message. I'm a few blocks from Advanced Auto Parts, so I went over there to get the battery checked and codes read. Battery and charging system are fine, and the OBD tool reported a PO600 (or P0600?), which is a general communication error, if I'm not mistaken. I reset the code and drove it 20 minutes home, and it appeared to drive normally.
I didn't have good light by the time I got home, but I'm going to check the trans fluid in the morning. If fluid isn't the problem, I don't know what is. I was going to take it up to Orlando on Sunday, but now I'm not sure that's a good idea. It was too late in the day to take it to a shop/dealer, but I did call around to several volvo techs to try and make sense of it. Opinions ranged from battery/alternator, ABS module, faulty transmission, CEM, PNP switch, or something else entirely.
I'm going to take it to someone on Monday to get it checked out, but I was wondering if this kind of thing sounded familiar to anyone, or if anyone has ideas on how to start diagnosing the issue.
