how to replace V50 climate Blower?
This topic is in the MVS Volvo Repair Database » How To Get The Blower Motor Out - Volvo V50
tozito
Year and Model: 2004
Post by tozito »
Hi forum!
I have to replace my fan climate blower The problem is how to access it! It seems to be a pain in the...
Did anyone manage to change it easily? Any link would be great!
Thanks to all.
thewhitegorilla
Year and Model: 2006
Post by thewhitegorilla »
its a pain in the tail, Im 3/4 of the way getting it out but can't release the catch and twist the motor out. any experienced help will be appreciated. But in answer to your question remove the gas petal and the brake petal. various length nut drivers and different length sockets 10 and 13mm, and a lot of plain its gonna come out attitude is what gets them out. The toughest part is ignoring the pain that you feel in your back due to the awkward position you must work from. Some others have said to remove the glove box and remove the housing from the passenger side. The writeup I was reading was from a c30 similar, but Im almost thinking that this extra PITA (again very awkward positioning must be attained to achieve removal)is not necessary on the 2007 V50. I will let you know when Im sure. I have mine removed but still inside the dash. The impression that Im getting is that the blower motor can be removed from underneath with both petals removed . It looks like it anyway. For now I am trying to get this catch released and get the motor out. Anyone any ideas? here are the pics there is one catch directly above the electric connect and then there is a rectangular recess on the round end of the housing. Anyone know how to release this catch?
thagorilla
thewhitegorilla
Still hung on this blower motor I know it twists slightly to come out but I I don't feel the catch like on a c30 , and the other location the rectangular at the very middle of the round side seems to do nothing. Anyone have one of these that you could look at and tell me the location of the catch?
thagorilla
thewhitegorilla
Ive found the catch but still cannot get it to budge save a small shift, I keep on working...
thewhitegorilla
I got it out, I had to take the seat out and lay straight in to get one hand on the blower and one releasing the catch heres a picture to help those after me. Look at the lower left at the middle finger in the picture
and right across from that is a round tab that' the catch, its a little scraped up as I was using a screwdriver then knife to try to hold it in as I turned They both fell out a dozen times easy, finally I took the drivers seat loose and got to where I could get a finger on the catch and turned the blower and it spun right out
thewhitegorilla
The motor does come out on the glovebox side under the fuse panel. A royal pain in the but just suck it up though you can do it for less than 50 bucks and the oem wants $1000=1200 to do it I have looked at the blower and the situation is that a couple maybe more of the fet power components are shorted and even the solder is mostly melted off of one of the pins. Eta of parts from china take too long I could repair it but a new blower is on the way from Florida be here in 3 days. The C30 blower removal tutorial was very helpful except that the blower was a little different looking.
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
Thanks for posting this- I believe it's been added to the repair database now!
