I just bragged on how great my 850glt runs after the PCV replacement and the turbo oil return line/gasket replacement. No leaks no smoke! Then my daughter drove it for several days with no problems and then tonight it "lost acceleration" and she parked it. I came a few hours later & checked it out...no leaks or suspicious activity, it started right up, it drove and then I parked it and would not go into gear after that, forward or reverse. I shut it off & checked tranny fluid and it was runny light brown and overfilled . What did I do? Coolant is clean as is oil.
Gonna tow it to my generic shop & would love to tell them what to check. Any ideas?
Thanks!
Transmission problems....what have I done now?
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
Sounds like the transmission cooler is leaking. Have the shop dump the transmission sump and thoroughly run new Dex III through it to flush out the TC as well. Then pressure test the radiator cooler.
Hopefully the transmission can be salvaged...but usually antifreeze is the end of em.
'98 S70 T5
2016 Chevy Cruze Premier
wheelsup
- Year and Model:
- Has thanked: 16 times
- Been thanked: 22 times
Yeah, the way coolant mixes with transmissions I would have expected a separate cooler mounted completely away from the radiator. Unfortunate many manufacturers still do this.
- Been thanked: 504 times
Do a simple drain + refill (about 3.3 qts of Dexron-III), and see what happens.
All you need is a 24-mm wrench (search forum).
However, I am afraid your transmission is going south.
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
If you have the money for a rebuild it might be nice to have all the internals replaced but a tranny swap might be the cheaper option. I would call around and see what shops are charging for a rebuild and compare that to the cost of a transmission.
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
You could find another 855 for the cost of transmission rebuild.pikngrn wrote:How much should I expect to pay for a transmission rebuild?
I haven't had tranny trouble in 30 years.
I just remembered that it is mostly water in the radiator because I was afraid to put antifreeze until I knew I had no leaks. I had a hard time getting a heater hose to stay in before I started the PCV job. Would water mixed in hurt just as bad?
- 17 Replies
- 3278 Views
- 497 Views
Last post by 57gretsch
- 551 Views
Last post by Cees Klumper
- 849 Views
Last post by Georgeandkira
- 912 Views
