I'm getting a P0011 code on a 2006 S40 that I recently purchased at an auction. Its has 130Kmi on it.
I doubt the timing belt has been replaced. Specifically my code reader says P0011 Camshaft Position Sensor Intake Camshaft Position Timing _Over_Advanced. (Bank1)
Any ideas on trouble shooting this?
Thanks in advance :-)
Phillip
P0011 engine code
- Year and Model: Many Volvos
- Been thanked: 76 times
It is usually indicative of a problem with the CVVT valve, either electrical or mechanical, or a problem with the pre-load on the timing belt. Was the belt recently changed?
Thanks Lee, I'm still getting the P0011 engine code. Camshaft Position Sensor Intake Camshaft Position Timing_Over_Advanced (Bank1)
The engine seems to run fine.
When I clear the code it comes back within a mile and on the 2nd key start. The engine seems to run OK.
1. I checked the oil and the oil is full and clean with only 1000 miles on the oil.
2. I do not think the timing belt slipped because I found the timing marks on the top pulleys and they both line up perfectly with the notches in the timing belt cover.
3. I replaced the VVT Solenoid with a new Volvo VVT Solenoid
4. I checked the wiring to the VVT Solenoid and getting 13volts there to the new VVT Solenoid.
So am I correct in thinking that the camshaft position sensor it's self is the next thing to check clean, or replace?
The car has 130k miles on it I don't know when or if the belt was changed however there is still Volvo paint on the belt(I know I know that paint thing means nothing.)
Thanks
Phil
Thanks
Phil
toyznstuff
- Year and Model: V40 2000
My 2000 V40 has the same Camshaft Position Sensor code come up too. forgot the # but also states 'advanced' ignition timing. Now the 'problem', I can't find it... There is a place for what I think is where it goes, two small bolt holes on the right side @ top. Mine just has a blank space there that looks like a 'freeze plug', but a little bigger. I actually changed on of these on a 2006 PT Cruiser, it's not a difficult job, if I can find it. Have a Haynes (useless) manual & original owners manual. Chilton doesn't make a manual for this year. So if anybody has any pics/images, please post them. I went to the junkyard & found a 5cyl T about '99-'00 & it had the Camshaft Position Sensor in the same place where mine should be!?!
toyznstuff
Found it in the Hayne's manual, but it was referenced from another section, and mine is missing...
- 3091 Views
Last post by jbkeene
- 1990 Views
Last post by FLXC90
- 16 Replies
- 12094 Views
Last post by Austingrayy
- 643 Views
Last post by Cal01s80
- 1908 Views
