96 960 spark plug change
lindy8_man
- Year and Model: 1998 S90
The Large black plastic strip that says 24 valve needs to be removed. You must have a Torx wrench set. You will see the plugs lined up under there. Each plug has a coil located directly above the plug. There might be a screw holding the coil down. Take out the screw, then pull the coil and plug connector from there. Follow the standard replacement procedure from there!
Beer and DIY Volvo Repairs are proof that God loves us and wants us to be happy.
- 3140 Views
Last post by Roger_850T
- 3952 Views
- 1976 Views
- 1177 Views
Last post by FLXC90
- 11767 Views
Last post by MoosePond123
