''Amp End'' cable (speakers) pinout Please:)
VolvoFun
Year and Model: S60 2005
Post by VolvoFun »
Hi all Volvo lovers:)
I'm looking for pinout of amp end cable (speakers one) for my volvo s60 . I have HU-850 and amplifier under seat 4x50W ( 8673135). I'm planning replace this amp to rockford's ones.
Picture below: mark green :)
Thanks Guys!
mikealder
Year and Model: V70 2000
Been thanked: 13 times
Post by mikealder »
Do you know what each of the pins on the Rockford amp are for, sorting out what is under the seat on the S60 is quite easy:
Amp remote on/ off is in the six pin DIN plug
Pre-out signals to the amp are all in the six pin DIN plug.
The speaker wires are the pairs of grey twisted wires out of plug B
Power to the amp is on Plug A
Try Here for the diagrams, note the audio diagram is split in two with the head unit on one page and the amp much further in to the pdf - Mike
VolvoFun
Post by VolvoFun »
Hi
Thanks;-) I've got din cable done, power will be from battery. One more question: speakers wire with red line are + or - ?
Regards
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
There is no rhyme or reason to the factory wire colors and polarity. If you look on the schematics the polarity is identified at the factory amplifier / head unit. Just correlate the polarity to the wire color associated with that pin.
mikealder
Post by mikealder »
There are four sets of twisted pairs from the amp to the speakers, in each case the grey wire with either the white stripe or the one with the red stripe is the + the solid grey wires with no other colour is the speaker neg - Mike
VolvoFun
Post by VolvoFun »
Thanks Mike:)
I'm still waiting for amp delivery (4 channel MTX) & small sub jl audio 10W0. I hope to plugin all on this weekend without problems:)
btw
Can I buy somewhere ''male socket'' to this female plug with speakers? I really don't want cut original instalation in the car.
What You think Guys about this custom subwoofer enclosure for s60 ? It's quite expensive ( around 500$ incl delivery to Uk) or maybe I can buy somewhere here in UK ?
Thanks again
mikealder
Post by mikealder »
If you get a SOT-043 ISO Adapter cable you will get the connectors you require which you can then hack to the non OEM amp, one post I made a while back covering the installation of the Bluetooth kit to an S60 might be of interest and supply a few tips to getting at the amp see Here - Mike
VolvoFun
Post by VolvoFun »
Thanks Mike!!
