Hello there!
Thanks for the great info on this site..! I have a few questions maybe someone can help with. I recently bought a 2000 S80 T-6 w/20,000 original miles...I've already spent a few weekends replacing stubborn blinker and headlight bulbs and recently had a radiator leak repaired...(guess the extended warranty was a good choice). A few questions...does anyone know if the controls on the steering wheel are supposed to be illuminated? And has anyone dealt with an annoying "squeak" from the dash/glove box? I've managed to tighten every screw visible but it always seems to return after a few days. Thanks!
S80 squeaks and lights Topic is solved
I'd Pass on This Used Volvo
guest
I've had that glove box squeaking for the entire time i've owned my S80 T6. I gave up and just stuffed it with enough stuff so its hard to close, that takes care of the noise. get ready for a whole host of problems. I hate my 2000 S80 T6. For the few weeks a year when nothing is wrong, its a joy to drive, otherwise, problem after problem. 3 oil leaks, front suspension replaced, shocks, fuel system cleaned.... I even tried calling Volvo. They are in bed with the dealers and do nothing but direct you back to the dealers that charge a fortune. good luck.
In answer to both questions. There is a chassis break as regards the illuminated radio controls. The early cars do not. I believe that mid 2000 on is the point at which they were illuminated. You do not have a problem. As regards the glovebox squeak, there is a fix. We would wrap the striker hook on the glovebox with a special tape from Volvo. There is a factory bulletin on this manner. I have also found that the fuzzy side of velcro applied to the glovebox door (inside) helps also.
- 770 Views
Last post by mydamnvolvo
- 1262 Views
Last post by sleddriver
- 13 Replies
- 1879 Views
Last post by rspi
- 3476 Views
Last post by BEJinFbk
- 1743 Views
Last post by CDoore54
