Now it is summer and is presenting a daily problem. The smell is NOT present when the AC is on full force. It is once the car is at a good comfortable temp. and I turn the air temp closer to 68 or 70. Then within 3 minutes there is a funky smell. Kind of stale smelling, kind of moldy. It makes me sick, and I either have to turn the AC up very high and freeze (and waste gas), or turn it off and open the window. Oddly enough, we went to Florida a few weeks ago. I was dreading the trip because of the smell. We operated the AC normally and did not have the smell once. That included the drive down when I didn't have to run it full force, just normally at 70 degrees on automatic fan.
Smell in the AC
ifarrar1
volvosonly
- Year and Model:
I've also frequently noticed a "fishy type" of smell coming from my a/c too. I was informed it was due to the filter. I still smell it, but only when I just turn it on.
- Has thanked: 2857 times
- Been thanked: 1332 times
Give this a shot: spray a disinfectant (Lysol etc.) in the AC intake with the filter removed.
john200981
http://www.k2distributing.com/pages/che ... -kits.html
http://www.dwd2.com/
The DWD2 I have read the most about..... have not tried it personally
rogeej
I would check the drain from the condenser. If you get water sitting in there it can turn into a pretty skanky pool
rainman
Drainage holes can be blocked and need cleaning out with compressed air. If you don't do this, the a/c system still works, but the damp environment creates mould spore farms (much stinkiness). Spraying with stuff will only create a temporary solution, you'll need to get the drain holes, 'blown out' with compressed air, then spray all the affected part with a spray that will kill the mould spores (your hardware store should supply this stuff). Make sure the spray you use, is safe for your car as well (dashboard etc)
