Grrrrr, my daughter's car, 1,600 miles away is stalling right after she starts the car unless she feathers the gas pedal. She said it revs high then tries to stall.
She had a spare fuel pump relay and swapped that to no avail. What should she try next? She said she has no codes so I think it is gas related...
'98 Volvo S70 GLT starts, revs high, then tries to stall.
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
drgswede1978
- Year and Model: XC70 1998
Could be a hose come off the IAC valve.
- rspi
Contact rspi..
Lol, that's funny, I think I put the lower hose on with a zip tie last time I seen the car about a year ago.
drgswede1978
I think that's your problem
Obviously check the air hoses are all in one piece and firmly attached, but one very easy thing to try is disconnecting the plug from the MAF - if it's faulty it doesn't necessarily throw a fault code and the car should run OK-ish without it connected.
- rspi
Contact rspi..
So I post a video for her to do the job:
1. Pull injector connectors guard off rail.
2. Bleed pressure off rail if running within 2 hours.
3. Pull the 2 bolts from the rail. (Oh, wait... only 1 bolt. Where is the other bolt? Is this missing bolt why the injector is loose? Call dad, sub bolt, push in rail, install bolt, all is good).
Problem solved. Wow
Problem solved. Wow
- Has thanked: 311 times
- Been thanked: 817 times
So the whole problem was that one bolt was missing from the fuel rail?
- rspi
Contact rspi..
Yep. Amazing. The fuel pressure was pushing the injectors out of the rail on the loose end.
So there was indeed a huge vacuum leak, due to the injector being out. That's a good one to know about, thanks for posting up the resolution.
- 23 Replies
- 3583 Views
Last post by DaveenBavari
- 11 Replies
- 2317 Views
Last post by erikv11
- 1947 Views
Last post by volvolugnut
- 1528 Views
Last post by mark0006
- 22 Replies
- 3445 Views
Last post by BEJinFbk
