replace front and rear engine mounts.
- christophervolvos80
- Year and Model: 2000 Volvo S80
Does anyone know where to find a good resource on how to replace the front and rear engine mounts on a 2000 Volvo s80?
Thanks,
ChristopherVolvoS80
ChristopherVolvoS80
You need to be more specific. AFAIK there is no rear engine mount, there is one on the bottom passenger side, and the one at the top, both like to fail and the replacement procedure is documented very well on the forum. There is also a youtube video you will find.
is for the 850. I've heard it's quite similar to the S80 mounts. There are 5 total as far as I know: top, transmission torque mount, right wheel well, and the front/rear hydraulic mounts (http://www.ipdusa.com/products/5573/112761-engine-mount). Those seem to be the ones the original poster is talking about.
Thank you, those were the mounts I were looking for but didn't know the names for. Also, would you know what would be a good repair manual to buy? Is Chilton a good one to start with? Thanks.
Thanks,
ChristopherVolvoS80
ChristopherVolvoS80
Are you sure these need to be replaced as they very rarely fail? Regarding the repair manual, there are links on the forum where to get the official Volvo VIDA application used by their service shops.christophervolvos80 wrote:Thank you, those were the mounts I were looking for but didn't know the names for. Also, would you know what would be a good repair manual to buy? Is Chilton a good one to start with? Thanks.
- regent
- Has thanked: 2 times
- Been thanked: 12 times
The hydraulic mounts seldom fail. There should be no need to change those (unless you see them leaking)
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired
1987 340 DL - retired
2015 BMW 335i
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 113 times
- Been thanked: 115 times
If you are referring to the engine pad, I have replaced both...https://www.matthewsvolvosite.com/forums/viewtopic.php?f=1&t=60920.christophervolvos80 wrote:Does anyone know where to find a good resource on how to replace the front and rear engine mounts on a 2000 Volvo s80?
The two pads, front and rear, require lowering subframe a little (18mm) while supporting engine from the above. Remove all three engine/transmission mounts before starting on the front engine pad, then move to rear.
Front requires removing the fan assembly, while rear will need disconnecting the steering column u-joint.
If not careful, the ps axle cv-joint would damage if engine is raised above 25mm. Jack-stand is OK, I would prefer to raise it with wheels on the ramps, eliminating any chance of PS cv-joint from failing.
Various engine related pads and mounts http://www.rmeuropean.com/volvo-parts.aspx#Category
Thanks. After checking the mounts I found that all of the sub-frame mounts (or bushings) and the engine mount (right under the camshaft) were all okay and did not appear to be cracked or broken. I did however buy the IPD Sub-frame Bushing (http://www.ipdusa.com) Inserts into my bushings for added measure and I did replace the transmission torque mount as well as the upper engine mount. All seems to work very well for now.
Note: After a few months and about 3,000 miles plus later, I notice that the upper engine mount is tearing again due to the high heat and vibrations i guess. I might need to replace it again in a year or so.
- Inserts I bought from IPD USA for $60
- ipd_23517.jpg (110.02 KiB) Viewed 3482 times
- New transmission mount from IPD USA $50
- ipd_16166.jpg (91.1 KiB) Viewed 3482 times
Thanks,
ChristopherVolvoS80
ChristopherVolvoS80
- 886 Views
- 7553 Views
Last post by theWIFES_S70
