I own a 94 850 turbo where the AC will not cool above 2000 RPM's. While idling the AC is cold and will cycle once in a while the gauge shows levels are good. It works fine as long as I keep the RPMs below 2000 which is real hard. Once I over the 2000 RPMs the compressor will not kick in until the car is restarted.
I thought it must be the high pressure switch and have swapped it out. A mechanic told be to change the cycle switch but I don't know where to look.
My neighbor has an 02 V70 that is doing the same thing, only difference is theirs doesn't show a pattern and some days the AC works all day.
Any suggestions.
Brian
1994 850 Turbo AC inoperative MVSOLVED Clutch gap problem
That sounds like classic compressor gap problem. It can be fixed by reshimming (for purists) or by the googable "Volvo AC bread clip fix"
I should point out that, if I race it off the line then let off the AC will stay on, it only happens if I drive continually faster than 2000 RPMs. Also, I can turn the AC off and after a few moments it will kick back on but that only happens once in a while.
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
Cooling Fan or Compressor?csbrianp wrote:I should point out that, if I race it off the line then let off the AC will stay on, it only happens if I drive continually faster than 2000 RPMs. Also, I can turn the AC off and after a few moments it will kick back on but that only happens once in a while.
Never mind ghetto clutch gap worked. Thanks guys.xHeart wrote:Cooling Fan or Compressor?csbrianp wrote:I should point out that, if I race it off the line then let off the AC will stay on, it only happens if I drive continually faster than 2000 RPMs. Also, I can turn the AC off and after a few moments it will kick back on but that only happens once in a while.
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
- 11 Replies
- 6925 Views
Last post by ThreeBear
- 2452 Views
- 2716 Views
Last post by victoriaemmy
- 2188 Views
- 1090 Views
Last post by E Showell
