1998 V70 Front end squeak. But I replaced everything.
Jicafold
Year and Model: 1998 V70 T5
Post by Jicafold »
I replaced my front upper spring seats with XC90 seats, new Bilstein Touring struts, new end links, new lower control arms, new cv axles. I did it all except the strut mounts. I also cut 1/4 turn off the springs and the pigtail still sits in the spring mount. Lately I've been noticing a squeaky squeaky in the front end. I can make it go away if I give it a touch of gas. When I let off it returns. It also goes away when it rains, as if the water temporarily lubricates it. I figure it is either the strut mounts or the springs are rubbing the mounts now that they are cut and sit in there just a bit differently. Opinions?
Has thanked: 1611 times
Been thanked: 4071 times
Lower engine mount or torque today (upper mount )
Common failure in high Mileage cars
Jicafold
Post by Jicafold »
Well, the upper mount is a poly mount and I know that is good. How many lower mounts are there and where are they?
Big one is front of motor, right under timing belt. Evaluate on lift
Jicafold
Post by Jicafold »
Excellent. Thank you!
