Hi There,
I have a 2002 Volvo C70 manual with a M56 gearbox. The clutch is ready to be replaced now, it's slipping when the turbo boost kicks in. The ECU has been remapped quite heavily and we're running higher boost pressure with more aggressive timing/fuelling.
I believe this model has a Dual Mass Flywheel. Is it worth converting to a Single Mass flywheel with the performance increases that have been made? If so, can anyone recommend the correct parts and where to get them from? I'm in the UK.
Any help, suggestions, advice and opinions are welcomed.
2002 C70 Clutch and Flywheel
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
Bump.
I'm curious to hear responses to this as well.
- Has thanked: 1506 times
- Been thanked: 3819 times
Might be better to post in performance forum? I'll move it but leave a tag here in a few days
