2001 xc70 Cannot remove rear tire off of hub
opgpc0
Year and Model: v70 1998
Post by opgpc0 »
Hello
I was a victim of a punctured tire last week. Rear passenger. I figured this would be a good time to replace both rear tires with some snows. I removed the flat tire, no problems. On the good side I removed the lugs but cannot get the rim off of the hub. I have tried heat, PB Blaster, prybar,deadblow hammer. It will not budge, any suggestions out there.
Also I would perfer to mount some steel rims for the winter. Is it true that the Ford Taurus will fit on the 2001 XC70. Any other rims that can fit on the XC70 volvo or other model
Thanks
G
draser
Year and Model: 2005 S60 2.5T
Been thanked: 2 times
Post by draser »
You exhausted all my ideas, I was going to suggest liquid wrench/wd 40 in the lug holes and center rim if you can remove the cap. Then wack the rim around perimeter with a piece of wood and hammer. Worked for me a while back.
2005 Volvo S60 2.5T, Zimmerman/Akebono brakes
2012 Honda Accord, EBC slotted rotors
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
Mmm, don't know if it's a safe idea, but maybe unbolt just a bit the lugs, then drive the car slowly in a parking lot left and right. But it can damage the flat tire.
vtl
Year and Model: 2005 XC70
Has thanked: 129 times
Been thanked: 686 times
Post by vtl »
Keep kicking the wheel at the edge of rim, it will eventually come off.
DGM
Year and Model: V70 2.4i 2005
Been thanked: 3 times
Post by DGM »
You can try this ;
V70 2005 2.4i 195,000km, sold
S70 1998 T5 355,000km, sold
960 1994 80,000km, sold
760 1990 Turbo 265,000km, sold
vtl
Post by vtl »
DGM wrote:You can try this ;
A healthy 200+ lbs male can do this with his boot :)
opgpc0, add some silicon grease, so next time it won't be so painful...
draser
Post by draser »
Good point with smearing grease on back of rim and face of rotor, I use wheel bearing grease after a good surface clean...
Vlvspd
Year and Model: 1998 v70 XC
Post by Vlvspd »
Did you ever get it off? You want to be hitting the rim from the backside. Grab a 4x4 piece of lumber or a bigger dead blow.
donnie
Year and Model: v70 2003
Post by donnie »
pour boiling water rround centre of wheel should loosen it
Has thanked: 1609 times
Been thanked: 4064 times
Vlvspd wrote:Did you ever get it off? You want to be hitting the rim from the backside. Grab a 4x4 piece of lumber or a bigger dead blow.
4x4 by 8 foot, under car, propped up to apply force to tire, hit from other side with sledge. This was the most drastic tire removal I've ever had to do.
Afterwards, wire brush face of parking brake drum and wheel, and apply a thin film of grease.
