1996 850 Wagon NA Heater Hose Leak
banjoman
- Year and Model: 850, 1996
223,000 miles. Replaced all coolant hoses, thermostat, sensors, and heater core. The new heater hoses and O-ring kit are Volvo from FCP. Put new coolant in reservoir and have major leaks from both ports in the coupler on the engine side and a small leak on the other side in the cabin. I followed the sequencing for the O-rings and spacer and made sure to remove the old spacers and O-rings; I understand the difference in the old coupler and the new. The new hoses and couplers went into the ports and clicked closed. I was careful throughout and did not notice any damage. I have seen the other posts about bypassing the current setup but want to avoid that.
- dosbricks
- Year and Model: '96 855, '98 S70
- Been thanked: 4 times
We have the same mileage on our S70 and I went through this ritual a few months ago--minus the leaks. It sounds like you were careful and informed on how to change out the o-rings/spacers. The only thing I can think of offhand is a cracked coupler (the black plastic housing everything inserts into). Did you also replace this? Sometimes they're brittle with age and crack when manipulated.
- dosbricks
Probably the culprit since there is some leakage on both sides.
precopster
- Year and Model: Lots
- Been thanked: 128 times
I always replace the coupler; they don't like being disturbed at all and will leak.
banjoman
To close the loop, the leak was caused by a bad coupler. A few comments most of which are explained better elsewhere . . . If you are replacing the heater hoses, install a new coupler; the one I got from FCP includes the O-rings, spacers, and yellow snap-on devices, so do not buy those separately. The coupler must be removed from the inside. Remove the accelerator by prying the pin on the left side about a quarter of an inch; the accel then slides toward you easily. Remove the upper and side screws on the heater core box and tilt it to improve access to the coupler. The old coupler seemed difficult to remove first, but then I realized that it was being held on by the thick foam insulation; go ahead and pull on it hard enough to get it out. When you install the new coupler, attach the metal pipes first; put some Vaseline on the O-rings and spacers so they slide in more easily. At first it seemed as though they would not go in, but keep at it and they will.
- 1993 Views
Last post by banjoman
- 23 Replies
- 6706 Views
Last post by callahanoffroad
- 16 Replies
- 4099 Views
Last post by PeteB
- 24 Replies
- 7713 Views
- 407 Views
Last post by Vova585
