Oxygen sensor difference?
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Yes.
Connectors are slightly different because of index pin position,but can be connected without problems if index pin is grounded,but not neccessary.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Ben850
- Been thanked: 7 times
It is an perfect indication of upstream or downstream that there may be a different length.
The adapters were introduced for an alternate down tube design.
They do not always think ahead.
1996 850 Turbo Wagon White.
1994 850 N/A Wagon Black.
1997 850 Sedan Black.
1996 850R Wagon White.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
When I searched a replacement for my front one, the rear one had a completely different design, and this for several Volvo engines. I believe they don't work the same, but it's only my supposition. The prices are also quite different. There is also a portion on the wire where the sensor is measuring the outside oxygen content.
I got a NTK (same as NGK) off Ebay for $100 and works well.
Ben850
They will be Bosch.oragex wrote:When I searched a replacement for my front one, the rear one had a completely different design, and this for several Volvo engines. I believe they don't work the same, but it's only my supposition. The prices are also quite different. There is also a portion on the wire where the sensor is measuring the outside oxygen content.
I do not have the exact part # handy.
Use Bosch only.
Edit: I realize you may be posting in the wrong forum. My answer applies to '93 to '98 850 series.
I am not versed as to '03 S60. Apologies.
- 1315 Views
Last post by brant
- 22308 Views
Last post by loveMy850
- 27 Replies
- 4074 Views
Last post by shiloh51933
- 3283 Views
Last post by ZionXIX
- 810 Views
Last post by olfac87
