1998 S70 A/C Won't Engage
shaker_chi
Year and Model: 94 850, 98 S70T5 M
Has thanked: 3 times
Been thanked: 3 times
Post by shaker_chi »
I have a 98 S70 T5 that I don't drive often, but I pulled it out of the garage this past weekend and when I attempted to turn on the A/C the compressor did not engage. Last fall it was working, but after running for about 20 minutes I would get hot air blowing. I would then have to shut it down for about 10 minutes and when I turned it back on I would get cold air. Will the compressor engage without freon? Any suggestions would be greatly appreciated.
Eddie G
Has thanked: 1610 times
Been thanked: 4065 times
The classic weak AC compressor magnet, fixable with the
"bread clip fix"
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 112 times
Post by E Showell »
Might need a freon charge as well. I understand the compressor doesn't operate if the freon drops below a certain level. Not sure about that, but it is what I have heard.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Might just be low on refrigerant.
Do not perform "bread clip fix" ,because if you are low on refrigerant you will fry the compressor.
Check the refrigerant level at specialized service and let them take care of ac system.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
I missed that now it is not turning on. It does sound like you have lost charge.
Find leak - How old is your EVAP core on this car? 100 dollar part, 10 hours labour :-(
Fix
Evacuate
Charge
shaker_chi
I am confident my evap core is original to the car, but when I bought the car last year it did have a filter when I replaced it. I'll check the refrigerant levels this weekend. Thanks for the help!!
mika
Year and Model: 97 850 NA 98 v70
Post by mika »
get a broomstick and press on the compressor (with ignition in position 2 and AC button on). See if changing the gap (with pressure from stick) engages the compressor...
'92 945 Turbo, 13lb boost on E85 with 54lb injectors, 230k
'98 V70 N/A 174K , Konis Sport + H&R Blue springs,16 inch Solars
'97 855 N/A
Previous: Honda Fit Sport (RIP), Kymco S200 (missed),
'86 244 DL M46 (restored and traded)
misha
Post by misha »
It will not engage that way.
The engine must run because ecu is managing the function of automatic ac.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
