2001 c70 wheel interchange with s60 t5
- misha
- Has thanked: 155 times
- Been thanked: 432 times
They will fit just fine.
Central hole should be the same for both...65.1.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Thank you, but will 6 offset difference possibly have a tire rubbing issue with 225 45 17's. Will these be offset 6mm more towards the fender? I hope not to purchase and have them rub when parking. THANKS again.
- misha
Are you installing s60 t5 alloys with 225/45/17 tyres on c70 or c70 alloys on s60?
On c70...225 will not fit without spacers....i think.They will fit but they will rub just like on 850,s,v70.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- misha
Et number is like this....the lower number is-the bigger distance towards outside.The bigger number is-the bigger distance towards inside of a wheel arch is.
So....et 43 vs et 50 means that wheel with et 50 goes towards inside(closer to shock apsorber).
S60 wheels wil fit to c70 but 225 tyres will not fit without rubbing on the inside at full lock.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- 3747 Views
- 567 Views
Last post by jonesg
- 796 Views
Last post by projectPONY
- 1674 Views
Last post by deano1
- 1400 Views
Last post by Ben850
