Both of the doors do not sit flush at the bottom of the door. the top is flush but bottom bows out about 1/4 of an inch.
Any one with this problem and a solution
Thanks
1999 c70 bottom of door not flush
volvomadness
- Year and Model: v70 2003
- Been thanked: 9 times
- osman
- Year and Model: 2002 c70 hardtop
convertible?
Brick Life
2003 Saab 9-5 ARC V6 3.0 Turbo 120K SwagWagon
97 850R wagon mileage unknown
2000 C70 Turbo Convertible 110K
99 XC70 AWD LPT 115
98 BMW 328IS 130K M3 Wheels
94 Mercedes 420E 160K
Kiwi bluetooth/Torq Pro app VOL-FCR/VAG-COM USB cable
99 XC70 AWD LPT 115
volvomadness
no coupe
- misha
- Has thanked: 155 times
- Been thanked: 432 times
There are two draining holes at the bottom of the door.One at each side.They could be clogged.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
mikel
- Year and Model: 1966-2000-2003-2007
there are adjusting screws with lock bolts on each door under door panel and a paper or plastic cover. they might need adjusting or the hinges could have sagged. Not sure if the adjustment is for the door or the glass to move in or out as needed. I have the passenger side glass that is out to much at the top.
..m
..m
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
For mis-alignment at rear edge only: Remove the door panel. AT the top back of inside door are the bolts for the window cassette/door reinforcement. Loosen those 1/2 turn and then push inward on the bottom of the door with it open and hold while tightening those bolts. Sounds funky but it is the procedure for aligning the door at back edge to body.
If the door is the same amount out of alignment all along bottom: the adjustment is to loosen door hinges ad twist bottom of door inward.
- 1651 Views
Last post by MoVolvos
- 2210 Views
- 982 Views
- 1840 Views
Last post by precopster
- 1395 Views
