1998 S70 -- caliper rebuild kits
mar601
Year and Model: 1998
Has thanked: 34 times
Been thanked: 5 times
Post by mar601 »
when you buy these kits do I need (2) kits?
rear --
https://www.fcpeuro.com/products/volvo- ... v70-270902
front--
https://www.fcpeuro.com/products/audi-v ... -4a0698471
i'm an idiot, i know
tryingbe
Year and Model: None
Has thanked: 1 time
Been thanked: 26 times
Post by tryingbe »
1 kit is for 1 caliper.
85 GLH, 367 whp
00 Insight, 72 mpg
mar601
Post by mar601 »
ok thanks -- think i'll pass on them for now 150k on car -- putting on new rotors and pads, hopefully the calipers (after 17 years) will be ok. at that price, probably smarter just to buy all new calipers.
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
The REAR caliper attachment (where it meets the metal line) is usually seized for good.
I tried to undo the nut but rounded it.
So, if your REAR calipers boot is slightly torn, rebuild the REAR caliper in-situ.
I wrote a detailed procedure in that hydraulic rebuild thread.
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
It's fine to try to remove the brake line from the caliper, front or rear or whatever, I wouldn't give up without trying.
Use a quality flare nut wrench and possibly some heat (but not too much!). The rear one is a trouble spot, no doubt, but many people have removed that nut without issue. So far I have rounded off one nut, that is in about four or five tries.
chrafael
Year and Model: 1998 v70 GLT
Been thanked: 10 times
Post by chrafael »
I bought kits for my v70, but wound up buying calipers anyway because the pistons were badly rusted due to torn dust boots allowing water in.
