I bought my car with an intermittent ets light and wandering idle. bought a xemodex diy kit on ebay and installed it shortly after. It cured my wandering idle, but my ets light is still on. Throttle appears to function perfectly except I have no cruise control. I've been driving my car like this for 9+ months now...
Is there anything else I can do to try and fix my etm issue don't want to throw a bunch of money at it because I have no drivability problems
sorry I don't have the specific ets code my scanner wont read it have no check engine/obd codes
2002 c70 Ets light with xemodex installed
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
As I discovered, the ETM and cruise control are likely unrelated. The cruise issue is likely the switch in the stalk. I cured my cruise issue for a $10 pick n pull stalk with functioning switch.
Use your code reader to turn out the ETS light and don't look back.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
- RussB
- Year and Model: '00 S70, '04 S60
- Has thanked: 3 times
You may have a vacuum leak, which would also cause the cruise control to not work. Been there, fixed that!
'00 S70, '04 S60 and the never ending quest for Stage Zero
precopster
- Year and Model: Lots
- Been thanked: 128 times
A ETS light has nothing to do with faulty functioning cruise control, though cruise won't work while most ETM related faults are active. The ETS system can't know that you have a dodgy switch. If no connection is made at the switch the ETS system just assumes you're not activating cruise to the ON position.
In EShowell's car ETS light was off and cruise not active.
Without a Volvo specific scanner you may never learn the reason for the ETS light. It may be on due to a failed brake pedal position switch which is not performance limiting.
- 4490 Views
Last post by c70_lindsay
- 1463 Views
Last post by Ozark Lee
- 729 Views
Last post by coflynn
- 6856 Views
Last post by debb48
- 2246 Views
Last post by sk55
