So, I'm halfway through a rear brake job, including caliper replacement. New rotor is on and now I'm trying to disconnect the brake line nut. I'm noticing it is a bit rounded and am having trouble getting a flare wrench or even regular open ended 11 mm wrench on it -- I even tried a 10 mm wrench. I went to the small vice grips and even they aren't going to cut it. Any suggestions as to how to get that nut off?
I don't have a line flaring tool and I am doubting I can get a replacement brake line nut on a Sunday afternoon. I was supposed to take the car long distance tomorrow.
'98 V70 NA 5 spd; Brake Line Nut Help Needed
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
- E Showell
Thinking about another way to skin this cat. The caliper with the frozen nut is toast anyway. I am considering replacing the entire hard brake line going back to the junction over the rear crossmember -- about 4 feet of hard brake line. Does anybody know whether the brake line fitting that goes into the junction over the rear crossmember is the same fitting that goes into the caliper, or is it a different type of fitting? I am at the mercy of Advance Autoparts for fittings.
'95 855 auto (sold)
'95 855 auto (sold)
- Been thanked: 504 times
The EASIEST way is transplant the piston, seal and boot over the existing caliper body.
See Step #14:
https://www.matthewsvolvosite.com/forums ... hp?t=37721
See Step #14:
- dosbricks
- Year and Model: '96 855, '98 S70
- Been thanked: 4 times
Next time if you have one of these ahead of time, it's unlikely you will not be able to loosen that nut. It has tremendous gripping force.
https://www.amazon.com/Vise-Grip-Adjusta ... FR7ES2A4MZ
- E Showell
Going back and forth between a ratcheting flare wrench (10 mm) and an 11 mm open ended wrench, I managed to get the nut off and swap the caliper.
'95 855 auto (sold)
'95 855 auto (sold)
- 586 Views
Last post by E Showell
- 1071 Views
Last post by zombielinux
- 338 Views
Last post by kahl
- 404 Views
Last post by itsmekirby
- 14 Replies
- 2314 Views
Last post by MoVolvos
