Have a lot of coolant leaking and some oil -- found out today that it's all in the turbo area, the 2 hoses and a pipe? plus the turbo itself is leaking. (160k on car) Could someone give me an idea on repair cost (not a job I'll do myself) on rebuilding this entire area? Just assume worst case and the cost to replace everything associated with the turbo to get it back to new. Certainly the hoses etc are easy to understand but what usually fails wken the turbo itself is leaking? Is it a gasket or something?
Thanks VERY MUCH for any answers -- need to get this done right away.
1998 S70 turbo rebuild
tryingbe
- Year and Model: None
- Has thanked: 1 time
- Been thanked: 26 times
Rebuild the turbo, replace the coolant hoses, replace the oil return gasket and seal?
Without labor, probably around $300-500 for parts.
85 GLH, 367 whp
00 Insight, 72 mpg
00 Insight, 72 mpg
kahl
- Year and Model: 2000V70XC
- Been thanked: 10 times
Pluses to what Russ said, Look at the rear exhaust cam seal for leaks. leaking cam seal makes a mess around the turbo. Coolant is probably the short rubber hose from hell on the turbo. Then do a glove test to see if your PCV needs servicing which in turn can dislodge your cam seals.
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
- sleddriver
- Year and Model: 1998 V70 T5
- Has thanked: 11 times
- Been thanked: 13 times
Check out this video by ARD tuning:
Looks very straightforward, only requires simple tools, about 25 min. on the bench.
M1 10W-30 HM
M1 10W-30 HM
- Year and Model: Many Volvos
- Been thanked: 76 times
It isn't a bad job but the cleanup time got left off for the video. Usually they come off of the car just caked in grease and I soak them in kerosene for about a week before I even start to clean them up. You can use some other degreasers to speed that process up. I think JDS60R uses a heavy concentrate of Purple Power to clean them up.sleddriver wrote:Looks very straightforward, only requires simple tools, about 25 min. on the bench.
- 32 Replies
- 17606 Views
Last post by sleddriver
- 732 Views
Last post by chrafael
- 583 Views
- 1152 Views
Last post by rspi
- 1017 Views
Last post by tryingbe
