1998 S70 T5 -- manifold lock nuts
mar601
Year and Model: 1998
Has thanked: 34 times
Been thanked: 5 times
Post by mar601 »
Having some work done in a few days and Volvo wants 22 bucks each for these. Part # 977209 manifold lock nuts.
Too late to get the shipped from FCP etc (unless my local NAPA may have them) -- is there a nut I can get locally that is the same thing? Like through Fastenal, Grainger etc? -- thanks
153 bucks for 7 nuts is crazy but I do want the part to be OEM or better.
RussB
Year and Model: '00 S70, '04 S60
Has thanked: 3 times
Post by RussB »
First question, why are you having the turbo removed? I thought you were having the PCV system replaced?
Second, you need these particular nuts because all others will fall off. I've tried many. They have a retaining ring built into them, plus they stand up to the heat. I just removed the turbo from my '96 T5 and I had replaced all those nut back in '06 when re-building the head. They look as good as new and were easy peasy to remove. They were less than $6 each back in '06 from FCP
Third, they can often be re-used. Too bad you're not in southern New England, I'd be glad to help you out
'00 S70, '04 S60 and the never ending quest for Stage Zero
mar601
Post by mar601 »
yes, pcv and turbo issues. going to volvo tuesday -- thanks for the word on those nuts. I'm sure fastenal would have them but would need the specs -- no biggie, just trying to save a few bucks. this forum has always been helpful ++++++++++++++
RussB
Post by RussB »
mar601 wrote:yes, pcv and turbo issues. going to volvo tuesday -- thanks for the word on those nuts. I'm sure fastenal would have them but would need the specs -- no biggie, just trying to save a few bucks. this forum has always been helpful ++++++++++++++
No one has those particular nuts...no one!
These MIGHT work,
Flex-Top Expanding Locknuts for Extreme Vibration, M8x1.25 18-8 stainless http://www.mcmaster.com/#hex-locknuts/=zia8qj
