installed the ETM
volvobox
Year and Model: 2000 V70
Post by volvobox »
I now notice a surging Idle and when I turn the car off, I can hear a high pitch noise near the ETM is that normal?
no check engine light or ETS light
precopster
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
Was the new ETM matched to your car and programmed or just installed with fingers crossed that it's a match for your car? Did you buy part number 36050563? If so it will have a recent fw pre-installed for 2001 turbo but it may not necessarily match your car's ECM (engine control) version.
If the ETM continues to whine with ignition in Pos II and engine off I can tell you quite certainly that it's not a match.
volvobox
Post by volvobox »
8644344
volvobox
Post by volvobox »
I hear that high pitch noise when the ignition is off and the key out of the ignition.
don't know why the video uploaded upside down , but here's the noise
ChrisatXeMODeX
Year and Model: 2013 S60 AWD
Been thanked: 2 times
Post by ChrisatXeMODeX »
The ETM should not whine with the key out of the ignition. Disconnect the ETM plug and see if you have 12V there with the key out. Link to ETM diagnostic flow chart.http://xemodex.com/us/knowledgebase/etm ... 1999-2004/
volvobox
Post by volvobox »
What if there is 12V?
ChrisatXeMODeX
Pull the engine management relay out, it might be stuck.
volvobox
Post by volvobox »
When I pull the engine relay out it stops and when I plug it back in it stays off.
until I start the car again
volvobox
Post by volvobox »
So, I start the car, Idle goes above 2k rpm then drops down to 1100 rpm and then goes up and down in oscillations.
precopster
With that part number this has to either be a V70 2001 or 2002 non turbo or a S60 2001 or 2002 non turbo. If you bought a used 8644344 it won't suit your car withour programming.
I checked that previous post of yours and I can see that you have a 2000 model V70. You most definitely have the wrong firmware in the ETM.
