Ok I know among car gurus this tends to be a hot button issue, but I'm not very familiar with these car(though I'm getting that way relatively quickly lol!). My V70xc has 140K on it and It's unclear if the tranny fluid has been changed at all. The previous owner wasn't sure if he had it done but I know by the title he only had it for 30K he almost never drove it as it was his second car. I believe he bought it from a dealer but don't recall from the former title where. The fluid looks fairly clear now the question, to change our not to? I've heard horror stories about these trannies, but this one is smooth and doesn't shift hard or anything. Any opinions are appreciated.
Thanks, Josh.
Transmission fluid change question.
- Has thanked: 311 times
- Been thanked: 817 times
No horror stories, the 98 trans is bullet proof.
The AWD on the other hand ...
blandis
- Year and Model: 99 S70 T5
- Been thanked: 3 times
If it is a 98, i had really good luck with Mobil 1 synthetic. Instant smoother shifts. Fluid choice is another hot topic as well, but used it in both of my previous 98's and the difference was instant.
Brad
Nashua, NH
2017 XC60 AWD
2006 XC90 2.5T
Nashua, NH
2017 XC60 AWD
2006 XC90 2.5T
It is the AWD, that's why I said that about the stories I've heard. I've been leaning towards changing it, I've had mixed experiences with changing unknown transmission fluid is past cars but with higher mileages on them though. Thanks for the input.erikv11 wrote:No horror stories, the 98 trans is bullet proof.
99 V70xc Darkwing (gone
08 xc90 Tabitha
06 V50 T5 Awd 6spd. Skeeter
66 barracuda "very long term project"
08 xc90 Tabitha
FlyingVolvo
- Year and Model: 2000 V70XC
- Has thanked: 51 times
- Been thanked: 74 times
Do a few drain & fills with Mobil 1 synthetic ATF. Good stuff, been using it for years. If you're really serious about making it last... I installed a Magnefine inline transmission filter as well as an aux fluid cooler. Been running strong over 75K with all that. Haven't done a drain & fill in probably 30-50K and the fluid is still bright cherry red.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
2023 V60 T8 PE
Josh, you want to change it slowly.
Drain out the pan into a clean container, measure what you remove, replace same amount. Repeat in a few months depending on how much you drive.
What you really want to avoid are the ' power flush' options offered by your local gorilla oil change place.
Thanks for the advice. I've always been wary of power flushes if any kind, more especially in older vehicles. I'll probably start that process this weekend when I do my oil change.
08 xc90 Tabitha
08 xc90 Tabitha
I know it is, and luckily the AWD is a separate system from the transmission! The 98 transmission is still bullet proof. If you have heard horror stories, they are not about the transmission. Or not about a 98.Oitsujosh wrote:It is the AWD, that's why I said that about the stories I've heard. I've been leaning towards changing it, I've had mixed experiences with changing unknown transmission fluid is past cars but with higher mileages on them though. Thanks for the input.erikv11 wrote:No horror stories, the 98 trans is bullet proof.
For the transmission, I agree just do some standard fluid changes by drain and fill.
For the AWD components, you are almost guaranteed to encounter issues, I would start thinking now about converting to FWD or spending a good chunk of time and money to keeping the AWD going.
- 1386 Views
Last post by pierremcalpine
- 1494 Views
Last post by darrylrobert
- 3421 Views
Last post by oragex
- 2874 Views
Last post by robrike
- 16 Replies
- 3726 Views
Last post by fourteen2hands
