What oil viscosIty for 04 v70R?
goldmandan
- Year and Model: 1999 S 70, 2000 V70
Wondering what oil viscosity I should use for the V 70 R is 5w30 good enough or should it be 0w40 or zero 30 synthetic of course
goldmandan
Ok I got 5-30 Mobil 1 synthetic. Is the oil filter same as the regular 2.5s??
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
For Florida, 5W30 is a valuable choice, 10W30 or 10W40 would be even better. I don't see too often a 0W40, Castrol does a good 0W30 made in Germany (do they sell it in the US?). The closer the range between the first number and the second one, the better. A 0Wxx is mainly for very cold climates start up. Mobil 1, Castrol Edge, Pennzoil Platinum come to mind. Mann oil filter is great, I think it's the same for 2.5 but better x2 check
mobil makes a 0-40 synthetic that meets all the specs and has a very low volatility, so very PCV friendly.
it's also fairly cheap
https://www.amazon.com/Mobil-120760-Synt ... 78Z05RYQBA]
and easy to come by.
goldmandan
Ok got Fram filter for the R, got 5/30 Mobil one Synthetic. Should be fine.
Thanks guys!
Thanks guys!
goldmandan
yes they do sell 0-40 I bought that for my Jaguar.
- oragex
If the car has never seen synthetic oil, the synthetic oil will quickly clog the oil filter with dislodged debris. Better leave the Fram filter for no more than 300 miles, then replace it with a better filter. Mann sells off Ebay for around $6.
- 43 Replies
- 21235 Views
- 17 Replies
- 9115 Views
Last post by Rattnalle
- 1072 Views
Last post by Georgeandkira
- 20 Replies
- 10245 Views
Last post by volvolugnut
- 718 Views
Last post by Krons
