spots on inside of windshield
bob850
Year and Model: 1996 850 Turbo wagon
Post by bob850 »
I have been getting spots on the inside of the windshield, on the lower 6" of the glass. They are generally round, various sizes, some as big as 1/2".
My heater core isn't that old, I think it is a Behr unit (I also had bad luck with the eBay "Estonia" units).
Anyone else get these spots? I'm guessing either coolant or refrigerant oil.
1996 850 Turbo Wagon - 175K miles, ARD Green ECU, Koni FSD, IPD sways, Snabb intake pipe, IPD HD TCV
1999 V70 T5M - 220K miles, M56H swapped, 2004 S60T5 engine, IPD sways, H&R springs, Bilsteins, TME catback, tune
2007 V70R, 55K miles, mostly stock
Has thanked: 1846 times
Been thanked: 1710 times
Does your A/C work?
Also check the drain for the heating system is not blocked or the drains in the firewall are clear and not allowing water to drain into the heating system.
bob850
Post by bob850 »
AC works. Drains are clear.
I'd say if it is just on the lower edge of the inside of the windshield (say bottom 6") then it is either a small leak in the heater core or the evaporator is starting to go. Your A/C maybe working now, but unless it has been replaced at some point it is running on borrowed time. It may leak for a while and then fail eventually. You could have the A/C system pressure checked and then have some dye added to the system to find if the evaporator is leaking.
