Temp control fan always on.
- Has thanked: 17 times
- Been thanked: 35 times
Are you talking about the fan at the front of the car or in your AC system? If the one in your engine bay that's usually a sign that the engine coolant temperature (ECT) sensor has gone bad. Does the temp of the car (as indicated on your dash) fluctuate? If it does, that's another indication of this issue. The fan starting on its own is suppose to happen but not after the engine has cooled completely.
Ah, okay... LOL. Yes, very strange that it stays on. You sure you don't have auto engaged with thermostat? Hmmm, but it runs even with the key out right? Then there has to be some cross bleeding between positive power wire somewhere... Sorry, I'm not much help. Hopefully someone who knows these units can chime in to help you.
depends on what always on is.
it does run the fan after shutdown to clear the evaporator so it doesn't get mold and smell bad.
so if it runs and then shuts off, normal.
if it runs until the battery dies, problem.
jquick1
- Year and Model: 2002 Volvo s60 base
I understand NOW that it clears the evaporator. NOW the fan(inside the car) doesn't stop blowing ever as long a car is on.this has nothing to do with the fan coming on to clear the evaporator. do I need to replace the resister?
- 1321 Views
Last post by richardgengle
- 1926 Views
Last post by Earn_est_89
- 1075 Views
Last post by aliff850
- 501 Views
Last post by barno
- 661 Views
Last post by cbova
