Broken Vacuum Check Valve
s_watts
Year and Model: 2006 S60
Post by s_watts »
So I was replacing the vacuum hose line coming into the manifold. This snapped when taking the hose clamp off. It is after hours and I need to travel this weekend. Is this a part that the volvo dealership would stock? If not is there a good replacement?
crankycar
Year and Model: 2004 XC70
Post by crankycar »
If you can get a check vale that big (hose size) , go for it, look at the arrow for direction to reinstall correctly..(on old valve). that happened to me also, I put a hooaky larger hoe and a reducer got me by till I got a new one, yes a pain because of location..
s_watts
Post by s_watts »
So I have had no luck in finding a replacement. The volvo dealership here has not been able to identify that part. I have a lot of time on http://www.volvopartswebstore.com/ and not been able to identify the part no so I can order it. Can anyone point me in the right direction? I have only been able to find the vacuum check valves for the brake booster.
Archer
Year and Model: 2002 V70/S60 T5
Been thanked: 5 times
Post by Archer »
Do you have a self-serve auto salvage yard in your area? You would most likely find one there. I removed the same/similar hose/check valve on my 1998 V70 T5 last week and was concerned about doing the exact same thing by twisting/pulling the vacuum hose off. Also, be sure to install in the exact orientation, check valve and hoses. I initially installed backwards and my idle was high at 1300 rpm's....re-checked my work and corrected it, idle back to 900 rpm' s.
Has thanked: 1609 times
Been thanked: 4065 times
Pull the broken piece out of the hose and JB weld back togther. You need to put a filet around the pipe to give the joint strength and degrease well, too.
