Timing won't lineup
- F250
- Year and Model: 2007 S60 2.5T
Are you talking about your '02 S60? If so, I believe it has a single VVT hub. You can also refer to my PDF for guidance on timing alignment which is a compilation of details from several sources. My PDF is targeted towards a dual CVVT hub setup, but the principles can easily be applied to a single VVT hub arrangement.
______________________________
Pete - '07 S60 2.5T, Gray FWD (Daughter's car)
My Garage includes '02 F250 7.3L Diesel w/285K, '03 Excursion 7.3L Diesel w/196K, '06 Outback Limited 2.5L w/228K, '99 4Runner 3.4L 2WD w/220K
- F250
Thanks. I just tried to compile all the useful info I found helpful to me while I was in the mode of a vertical learning curve regarding the VVT hubs.
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 534 times
eXACTLY WHICH MARKS DONT LINE UP.?
Are the 2 cam marks in sync with each other but out of sync with crank are all 3 out of whack with each other.
The crank pulley is keyed but the cam pulleys are not keyed .
Also, exactly how far off are the timing marks, try to be specific, one tooth off? 5 teeth off?
What is your history with this car, who did the belt previously.
- 682 Views
Last post by Ozark Lee
- 1430 Views
Last post by shawnmacananny
- 1852 Views
Last post by 93Regina
- 2800 Views
Last post by Boosted40
- 16 Replies
- 5299 Views
Last post by RickHaleParker
