Buyers guide
aahmes57
Year and Model: 1998 S70 GLT
Post by aahmes57 »
Looking at a 1998 AWD xc70 tonight for $1,000. I've never owned an AWD vehicle before. Aside from the timing belt, oil leaks, shifting, PCV, and any obvious stuff is there anything in particular with the AWD's I should be looking hard at? I was looking aroud the site for info but couldn't nail it down so I figured I can look again on the site after I post this in hopes someone would answer before 1430 today.
I know this is short notice but I just called about it. New listing.
Thanks for any and all advice.
John
1991 740 (saved a life)
1998 S70 Turbo caught fire, very sad day
1995 850 sold
1999 V70 Base daily driver
850 LPT
Has thanked: 335 times
Been thanked: 247 times
Post by 850 LPT »
First thing I would do is check if the driveshaft for the AWD is still in place. This might be hard to do if you don't have access to a lift, since it is really tucked in there. You may be able to lift one side of the car and take a look.
If it's out of car you can be pretty sure that either the angle gear or the VC or both are in need of replacing or rebuilding. If you are lucky the driveshaft itself was the only bad part, but it's hard to know without real troubleshooting.
If it is installed you will want to listen for any unusual clunks while driving. Vibrations can generate from a variety of things and may not generate from AWD components, so that's not a good indicator for the health of the AWD. From what I heard is that VC's can loose their silicone fluid which you may be able to see, and it means they are toast. You can check if the angle gear is leaking which means trouble as well.
The AWD systems on these cars are fragile, so don't get your hopes up. Even if everything is working as it should right now, you need to prepare for spending serious money in the future if you want to keep it going. A lot of people just take the driveshaft out and use the car in FWD mode.
I hope things check out for you.
Dirk
58' Porsche Diesel Junior
13' Honda Odyssey :oops:
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2864 times
Been thanked: 1332 times
Post by matthew1 »
Also -> Amazon link
aahmes57
Post by aahmes57 »
Thans for the advice.
Drive shaft is there. The seller stated an angle gear was replaced. Some leak underneath, There is an exhaust leak right after the CAT and the ABS light is on. I think the best advice I saw other then the post by Dirk is to have the car looked at by a local garage. Doesn't appear to be in bad shape. I may be able to pick it up for about $600-700.
Thanks John
1995 850 sold
Has thanked: 1611 times
Been thanked: 4075 times
Good luck John.
You could have $2000 of work to make it a daily driver so be ready for that on budget. That's worst case.
aahmes57
Post by aahmes57 »
You're right. $2000. I offered him $750 he said ok now he tells me he has a guy
coming tomorrow. I got a line into a local garage who's going to do an inspection for me.
So maybe I'll get a good look underneath plus a good safety inspection anyway. We'll see now what he wants to do.
If I'm meant to have it I'll get it, if not no big deal. I got my 99 running like a champ.
As always,thanks for your help
John
And thanks for the links Matt.
1995 850 sold
matthew1
Site Admin
Post by matthew1 »
No problem John. Keep a healthy bit of skepticism in your pocket and you'll do fine.
(IMHO I'm not too hot on this deal. Seller backs out of a deal, and the hood won't go up. "Hmm", even at $750.)
Also -> Amazon link
aahmes57
Post by aahmes57 »
I have to careful when talking with sellers because for some reason they like uninformed buyers. I sometimes may look like I know too much even though
I'm just a novice and learning.
I may let this one go, although, he never accepted the $750 so in my mind there is still room for negotiation. I may offer my a $100 over junk yard price. Like maybe 4-$500. All he can say is no right. It's not like I need it. Make it a summer project. If he didn't sell it. I'll start picking at every little detail. lol
thanks john
1995 850 sold
Take 500 USD off the price for each 'guy' who looks and doesn't buy.
