blower fan stays on? anyone?
kberyldial
- Year and Model:
I'll turn off my xc70 (2002) and the fan will continue blow air in the car. I won't notice it sometimes and then return to the garage an hour later and its roaring away. Anyone have this happen or have some language for me when I call the dealer to fix it?
- Has thanked: 17 times
- Been thanked: 35 times
This is common...depending on heat, how much A/C you've used, etc., the blower stays on to knock out the air in the lines, get rid of moisture build up and to cool your car. As long as the blower doesn't say on all of the time running your battery down, I'd count this as a blessing and enjoy the new technology in your P2 vehicle. In older 850's this didn't happen and there were and still are people replacing their A/C evaporator from the moisture that eventually rusts out that unit.
2001 XC70 35000 miles.
Find blowers blasting away hours after ignition off and key removed- both engine and fans in passenger compartment full speed
occasional dead battery which tests OK after jumpt start; alternator also OK
Jack Mendham NJ
Jack Mendham NJ
Now, that's not normal. Shorting to a power line somewhere is what I think.
JRL
- Year and Model: Several
- Been thanked: 16 times
Only the INTERIOR (A/C) fan should blow using the afterblow function and should not use up the battery.JSHIELS wrote:2001 XC70 35000 miles.
Jack Mendham NJ
It will start about 1/2 hour AFTER you shut the car off and run from 25 to 45 minutes
- 1533 Views
Last post by 93SCMax
- 795 Views
Last post by JeffHicks
- 1280 Views
Last post by Volvo by default
- 1328 Views
Last post by SandCastle
- 2080 Views
Last post by precopster
