Bought one (97 850T) that slid sideways off the road in the ice and the rear wheel way off caster. I assume the axle or rear control arm is bent or both.
I have another one on the rack dropping the rear suspension out for the parts (and to see how the good one should come apart).
Any advice on where to disconnect the E brake cables? they seem to run all the way forward in the interior to the lever and the pin at the rear does not look like it will easily come out. Can anyone point me to a write up or anything on how to do it?
thanks
Rear suspension advice
- greg850r
- Year and Model: a long list
- Has thanked: 5 times
- Been thanked: 26 times
05 Cross Country wagon
99 C70 Convertible
96 850R wagon
96 850T wagon
96 850 GLT 5spd N/A sedan -wrecked, ouch
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4 (2)
24' 454 Challenger
07 Softail Custom
02 Sportster Custom -sold
Parts cars come and go
99 C70 Convertible
96 850R wagon
96 850T wagon
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4 (2)
24' 454 Challenger
07 Softail Custom
- Year and Model: Many Volvos
- Been thanked: 76 times
You can disconnect the cable from the brake drum/rotor but you need to remove the rotor to do it. You will need to slack off the adjuster before you try to remove the rotor or chances are it won't come off for you.
Once inside, you can disconnect the cable from the actuator which is pictured here:
I have a writeup on the parking brakes in this thread:
How to replace volvo e brake pads
There are several others in the database as well.
- Has thanked: 2207 times
To disconnect the actuator arm, you will need to pull the center console to access the cable end at the parking brake lever. You will have to remove the lever arms for the cables to allow the cables to extend enough at the rear hubs to be able to remove the actuator arms.
- 12 Replies
- 3404 Views
Last post by RickHaleParker
- 965 Views
Last post by famfeld
- 12 Replies
- 2233 Views
Last post by harryhendo
- 1056 Views
Last post by Sommerfeldt
- 742 Views
Last post by alschnertz
