2003 S60 Accelerator Slow/No reponse
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
JimmySmith04
Year and Model: 2004 S60
Post by JimmySmith04 »
My 2003 S60 accelerator is starting to loose its response. This happened about 6 months ago and mechanic replaced throttle assembly with a used one. Issue went away and now it starting to come back.
This issue seems to start slowly and then gets worse of time...I can floor the pedal and nothing happens...let up a little and it will start to move up to speed fine.
Also, my 10A AC fuse always blows when AC is turned on. I did read that this is the same fuse as the accelerator and was wondering if this could be related.
Any help or ideas on this would be greatly appreciated.
Thanks,
Jim
doublebug
Year and Model: XC90 2007 D5
Been thanked: 7 times
Post by doublebug »
JimmySmith04 wrote: Also, my 10A AC fuse always blows when AC is turned on. I did read that this is the same fuse as the accelerator and was wondering if this could be related.
Absolutely.
If you have questions about Volvo firmware ask me. I may know an answer :)
JimmySmith04
What would cause this fuse to instantly blow when the AC is turned on?
doublebug
Post by doublebug »
AC clutch. Seems it somewhere is shorted inside.
JimmySmith04
It is possible to unplug this to test out?
doublebug
Post by doublebug »
Just switch AC off and put fuse back.
JimmySmith04
:) That should work...Thanks!
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
The a/c clutch has a magneto with a single wire to it,, maybe it's that wire that has a short somewhere
Has thanked: 1504 times
Been thanked: 3817 times
...and don't use defrost, which will turn AC on.
You could unplug the AC clutch and see if it's the clutch seized up or the wire shorting. I'll take the long odds on the clutch being seized up.
