Transmission fluid type for my 2001 Volvo V70T
Aaron1972
Year and Model: 2001 Volvo V70T
Post by Aaron1972 »
Hello all Aaron here coming to you from Monterey Bay Ca new to this site i have owned over eight different Volvos this is my newest yet owner of a 2001 Volvo V70T im changing radiator on the car lost a little tranny fluid diconnecting trans lines whay type of transmission fluid do i need to top it off after i reassemble everything? Also what type of coolant? Manual says AW5. Transmission oil ? Never heard of this i was also told dextron 3 and. ATF TOYOTA TYPE 4 ? Dont know whats in car now just bought it two weeks ago any advice appreciated thanks guys !
jbeebo
Year and Model: S60, 2005
Been thanked: 4 times
Post by jbeebo »
DO NOT use Dex/Merc tranny fluid. Proper fluid type is JWS 3309 which can be purchased from (of course) the Volvo dealership or the Toyota dealership as ATF Type4. Reason why you can use the Toyota stuff: Volvo uses an Aisan AW55 transmission, similar to that found in certain Toyota models. Aisan is the tranny manufacturer and they are the ones who specify the fluid type. Note, you can get it from IPDusa as well, click the link above to support this site: https://www.ipdusa.com/products/10543/1 ... nsmissions
Coolant is a dealer only item IMHO. The Volvo coolant is excellent and will give many many years of trouble and corrosion free service. You could use modern OAT type coolant from another manufacturer but won't save any $$ and might have some incompatibility so why bother. DO NOT use all-purpose coolant you'll find at O'Reilly's or other such auto stores.
https://www.ipdusa.com/products/11221/1 ... ze-coolant
Did you replace the o-rings on the tranny lines going to the radiator? Cheap insurance....
https://www.ipdusa.com/products/5777/11 ... l-kit-1999
And while I'm at it, Power steering fluid is not Dex/Merc type ATF. It's a special type; Pentosin CHF-11 or CHF-202. Surprisingly O'Reilly stocks Pentosin CHF-11 fluid.
https://www.ipdusa.com/products/5743/11 ... ring-fluid
2005 S60 2.4L (B5244S6), 175k miles
beigg
Year and Model: 850 97
Post by beigg »
ugh smh 850 Turbo fridge
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
Mobil 3309 or Toyota Type 1V (same fluid) THAT'S IT!
tays82
Year and Model: S60 2003 2.5T AWD
Post by tays82 »
Liqui Molly 1200 is also compatible.
vtl
Year and Model: 2005 XC70
Has thanked: 129 times
Been thanked: 686 times
Post by vtl »
Anything JWS3309-compliant will move your car, but you'll have at least slight jolts. This gearbox likes only original Volvo ATF.
JRL
Post by JRL »
He just needs to add a bit so why are you people giving him other options?
NEVER MIX FLUIDS, use 3309 or Type4 which is what is in there
vtl
Post by vtl »
I mixed original, Amsoil, Mobil 3309, Idemitsu Type-TLS, Valvoline MaxLife. Now back on original ATF (1161640), transmission works very fine.
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
I've had good luck buying from here over the years. Watch out for sales- sometimes they have a case for about $10 less: http://thelubricantstore.com/mobil-atf- ... gQodU5EEhQ
Aaron1972
Post by Aaron1972 »
Thanks for the reply everyone i did not replace the o- rings on transmission lines it seems like after i replaced radiator and lost a little tranny fluid the transmission now has very slight shifting flares coming to a stop more so in stop and go traffic and between 2nd and 3rd gear perfectly smooth on the highway and shifts fine as long as im not in stop and go traffic to long any help appreciated thanks !!
