I have a 1997 Volvo 850 T5. Ok, so the serpentine belt started shredding late at night while my wife was driving home. No safe place to stop, she was about 5 miles from home, she didn't really know what was wrong until she didn't have any power steering. By then she was almost home. The belt never totally broke entirely but the broken strands wrapped around the pulleys. When she got home none of the pulleys where moving. I replace the serpentine belt the next day and untangled the pieces wrapped around the pulleys. No problems, drove fine. She drove to work the next day, about 20 miles (mostly interstate), no problems. When she went to leave, about 10 min. after starting, while sitting at the light the engine just started making a "knocking/tapping", like there was no oil in the engine at all. Checked the fluids, only a half quart low. Not the problem. When she drove it on the interstate it doesn't want to go past 60mph, the engine literally sounds like a diesel engine at idle. I have checked some things that I thought it could be but came up empty. Any suggestions or a direction would be greatly appreciated.
Thanks for your help.
Engine suddenly sounds like a diesel.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Maybe have another look at the serp belt pulleys, maybe some piece got stuck into the alternator?
Also, on some engines the serpentine belt can get to the crank pulley and mangle with the timing belt. IMaybe remove the tb lower cover and have a look.
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
+1 on checking your TB
you say pulleys weren't moving, you mean they weren't being driven, or they were bound up?
If the belt had a sudden stoppage, or sharp pull from the serp getting jammed, it could have skipped a couple teeth, or maybe torn some loose that didn't give way completely.
Definitely a significant event warranting further investigation.
Current Volvos:
Prairiemaster1
- Year and Model: 1997 850T
Thanks for the direction. Will definitely check your suggestions.
- 1620 Views
Last post by kcodyjr
- 601 Views
Last post by E Showell
- 807 Views
Last post by Sommerfeldt
- 1140 Views
Last post by polskamafia mjl
- 1876 Views
Last post by bluebossa
